CRC til 256 byte data
J
john2020
Hej alle,Kan følgende kode kan bruges til at opdage en fejl i en datapakke med 256 byte?/ *
* Funktion: Do_CRC8
* * Beskrivelse:
* Beregner den CRC værdi, der tillægges den byte, og den gamle CRC værdi som en statisk værdi
* Return Værdi: CRC værdi
* Parametre: Input data byte skal CRC'ed
* Bemærkninger:
* Benytter en tabel drevet metode til at fremskynde tingene.
unsigned char Do_CRC8 (unsigned char xx)
/ / Denne procedure beregner
const unsigned char code Tabel [256] = (
0x00, 0x07, 0x0E, 0x09, 0x1c, 0x1B, 0x12, 0x15, 0x38, 0x3F, 0x36, 0x31, 0x24, 0x23, 0x2A, 0x2D,
0x70, 0x77, 0x7E, 0x79, 0x6C, 0x6B, 0x62, 0x65, 0x48, 0x4F, 0x46, 0x41, 0x54, 0x53, 0x5A, 0x5D,
0xE0, 0xE7, 0xEE, 0xE9, 0xFC, 0xFB, 0xF2, 0xF5, 0xD8, 0xDF, 0xD6, 0xD1, 0xC4, 0xC3, 0xCA, 0xCD,
0x90, 0x97, 0x9E, 0x99, 0x8C, 0x8B, 0x82, 0x85, 0xA8, 0xAF, 0xA6, 0xA1, 0xB4, 0xB3, 0xBA, 0xBD,
0xC7, 0xC0, 0xC9, 0xCE, 0xDB, 0xDC, 0xD5, 0xD2, 0xFF, 0xF8, 0xF1, 0xF6, 0xE3, 0xE4, 0xED, 0xEA,
0xB7, 0xB0, 0xB9, 0xBE, 0xAB, 0xAC, 0xA5, 0xA2, 0x8F, 0x88, 0x81, 0x86, 0x93, 0x94, 0x9D, 0x9A,
0x27, 0x20, 0x29, 0x2E, 0x3B, 0x3C, 0x35, 0x32, 0x1F, 0x18, 0x11, 0x16, 0x03, 0x04, 0x0D, 0x0A,
0x57, 0x50, 0x59, 0x5E, 0x4B, 0x4C, 0x45, 0x42, 0x6F, 0x68, 0x61, 0x66, 0x73, 0x74, 0x7D, 0x7A,
0x89, 0x8E, 0x87, 0x80, 0x95, 0x92, 0x9B, 0x9C, 0xB1, 0xB6, 0xBF, 0xB8, 0xAD, 0xAA, 0xA3, 0xA4,
0xF9, 0xFE, 0xF7, 0xF0, 0xE5, 0xE2, 0xEB, 0xEC, 0xC1, 0xC6, 0xCF, 0xC8, 0xDD, 0xDA, 0xD3, 0xD4,
0x69, 0x6E, 0x67, 0x60, 0x75, 0x72, 0x7B, 0x7C, 0x51, 0x56, 0x5F, 0x58, 0x4D, 0x4A, 0x43, 0x44,
0x19, 0x1E, 0x17, 0x10, 0x05, 0x02, 0x0B, 0x0C, 0x21, 0x26, 0x2F, 0x28, 0x3D, 0x3A, 0x33, 0x34,
0x4E, 0x49, 0x40, 0x47, 0x52, 0x55, 0x5C, 0x5B, 0x76, 0x71, 0x78, 0x7F, 0x6A, 0x6D, 0x64, 0x63,
0x3E, 0x39, 0x30, 0x37, 0x22, 0x25, 0x2C, 0x2B, 0x06, 0x01, 0x08, 0x0F, 0x1A, 0x1D, 0x14, 0x13,
0xAE, 0xA9, 0xa0, 0xA7, 0xB2, 0xB5, 0xBC, 0xBB, 0x96, 0x91, 0x98, 0x9F, 0x8A, 0x8D, 0x84, 0x83,
0xDE, 0xD9, 0xD0, 0xD7, 0xc2, 0xC5, 0xCC, 0xCB, 0xE6, 0xE1, 0xE8, 0xEF, 0xFA, 0xFD, 0xF4, 0xF3
ucCRC = Table [ucCRC ^ xx];
return (ucCRC);
)svar mig med nogle forslag og ideer så tidligt som muligt
hilsen
john
> Kan følgende kode skal bruges til at opdage en fejl i en datapakke med 256 byte?
Det ser plausable.
En 8bit CRC vil lade en masse dårlig pakker gennem uden at blive opdaget.Når flere bits i en pakke får vendt, eller hvis en byte går tabt du har en ru 1 ud af 256 chance for at de dårlige data, der har samme CRC8 som de oprindelige data, så den fejl ikke vil blive opdaget.
hi throwaway18
tak for din reply.have du forsøgte at gennemføre et CRC-16bit eller 32bit? så fald pls svar me.can du foreslå mig nogle gode bog, hvor jeg kunne hente mere information om gennemførelse af CRC?
Dit program er helt sikkert meget hurtigt, men det kræver meget af flash.
Hvis du har tid nok måske denne kode kan hjælpe dine.
Gomez
*** Funktion: crc8 ***
*** Beskrivelse: funktion til at calc crc8 sum ***
*** Input: pointer af gamle CRC beløb, nye data ***
*** Output: non ***
void crc8 (unsigned char * crc, unsigned char data)
int index = 8;
int fb;
do (
fb = (* CRC ^ data) & 0x01;
data>> = 1;
* CRC>> = 1;
if (fb)
* CRC ^ = 0x8c;
) while (- index);
*** Funktion: CRC16 ***
*** Beskrivelse: funktion til at calc CRC16 sum ***
*** Output: non ***
void CRC16 (unsigned int * crc, unsigned char data)
int index = 8;
unsigned char fb;
* CRC ^ = (unsigned long) data <<8;
do (
if (* CRC & 0x8000)
* CRC = (* crc <<1) ^ 0x1021;
anden
* CRC <<= 1;
) while (- index);
Kære Gomez
tak for din pseudo code.i vil forsøge at ud, men spiste du sikker på, at det wil afsløre CRC til 256 byte data? anyways
lad mig se output
hilsen
john
lad mig se output
