hvad status for MOS i to trin op, er korrekte
C
chibijia
ligesom det emne, jeg ønsker at designe en op og bruge hspice simulere det, men unluckiy i cant't få ønsket resultat,
vil jeg finde min resultere i hspice 'dokument af lis, det detaljerede oplysninger,
subckt x1 x1 x1 x1 x1 x1
element 1: m1 1: m2 1: m3 1: m4 1: M5 1: M6
model 0: nch.1 0: nch.1 0: pch.1 0: pch.1 0: nch.1 0: pch.1
region Saturati Saturati Cutoff Cutoff Lineær Cutoff
id-1.580e-06-1.580e-06-5.245e-13-5.245e-13-3.954e-06-2.603e-07
IBS 2.600e-18 2.600e-18-1.977e-06-1.977e-06 7.048e-18-2.579e-05
IBD 3.971e-07 3.971e-07-2.423e-25-2.423e-25 9.666e-15 2.076e-16
vgs 3.142e-02 3.142e-02 0.2.178e-13 1.083e 00-4.573e-01
VDS-4.633e-01-4.633e-01-7.479e-01-7.479e-01-3.142e-02-1.205e
00vbs 0.0.-7.479e-01-7.479e-01 0.-1.205e
00femte 4.347e-01 4.347e-01-6.396e-01-6.396e-01 5.327e-01-5.947e-01
vdsat 9.849e-02 9.849e-02-4.587e-02-4.587e-02 4.965e-01-5.213e-02
VOD-4.032e-01-4.032e-01 6.396e-01 6.396e-01 5.507e-01 1.374e-01
beta 4.185e-04 4.185e-04 2.301e-04 2.301e-04 2.378e-04 1.185e-03
GAM eff 4.693e-01 4.693e-01 4.056e-01 4.056e-01 4.525e-01 4.089e-01
gm 2.437e-05 2.437e-05 1.274e-11 1.274e-11 6.480e-06 4.773e-06
GDS 7.796e-08 7.796e-08 6.297e-14 6.297e-14 1.220e-04 2.215e-08
GMB 4.605e-06 4.605e-06 2.359e-12 2.359e-12 2.015e-06 3.561e-07
cdtot 2.705e-14 2.705e-14 1.221e-14 1.221e-14 2.535e-14 5.860e-14
cgtot 2.245e-14 2.245e-14 6.447e-14 6.447e-14 2.485e-14 3.184e-13
cstot 6.079e-15 6.079e-15 1.634e-14 1.634e-14 2.370e-14 9.057e-14
cbtot 2.328e-14 2.328e-14 8.786e-14 8.786e-14 1.407e-14 4.419e-13
cgs 8.396e-16 8.396e-16 1.290e-15 1.290e-15 1.181e-14 6.423e-15
CGD 1.483e-14 1.483e-14 1.290e-15 1.290e-15 1.231e-14 6.423e-15subckt x1 x1
element 1: M7 1: m8
region Lineær Saturati
id-2.605e-05 3.000e-05
IBS 3.867e-17-5.307e-17
IBD 5.495e-14-4.041e-15
vgs 1.083e
00 1.083e
00VDS-3.748e-02 1.083e
00vbs 0.0.
femte 5.415e-01 5.406e-01
vdsat 4.997e-01 4.675e-01
VOD 5.419e-01 5.428e-01
beta 1.333e-03 2.385e-04
GAM eff 4.691e-01 4.516e-01
gm 4.241e-05 1.003e-04
GDS 6.695e-04 3.926e-07
GMB 1.352e-05 2.833e-05
cdtot 1.272e-13 3.347e-15
cgtot 1.234e-13 1.822e-14
cstot 1.183e-13 2.356e-14
cbtot 6.530e-14 1.280e-14
cgs 5.981e-14 1.536e-14
CGD 6.286e-14 5.302e-16
Jeg vil blot mirrio den nuværende af M5 equateto m8which har 30uA, men resultatet kan ikke få den hjælp, ønsker veteran kan løse mig denne qustion.
Hi chibijia,check vgs, VDS, femte, vdsat, vbs er ens for både M5 og M8, hvis ikke så passer dem,
sin meget vanskeligt at matche de numre i kodestykket fra *. lis fil.så du må gerne vedhæfte den som en txt-fil, så andre også kan læse tallene let.
1. ting jeg fandt var ur M5 er i lineære regionen og M8 i mætning.som har fået mig til at tro, at en af de spændinger i anført ovenfor ikke matching for begge enheder.
kontrollere den.
Hope this helps.
Tak,
o tak for din explation men jeg har også en vis forvirring, jeg ønsker blot at få 30uA aktuelle på M5, som jeg levering M8 med 30uA, så jeg indstille M5 og M8 samme size.my netlist er
. subckt amp vin vin-vo2 vdd vss
m1 3d vin 5d 5d nch w = 4u l = 2u
m2 vo1 vin-5d 5d nch w = 4u l = 2u
m3 vdd 3d 3d vdd PCH w = 10u l = 2u
m4 vdd 3d vo1 vdd PCH w = 10u l = 2u
M5 5d vb vss vss nch w = 7u l = 2u
M6 vdd vo1 vo2 vdd PCH w = 10u l = 2u m = 10
M7 vo2 vb vss vss nch w = 17u l = 2u m = 2
M8 vb vb vss vss nch w = 7u l = 2u
cc vo1 vo2 2.2p
cl 3 0 10p
iref vdd vb dc 30u
. ender
x1 vin vin-3 vdd GND amp
. globale vdd
vdd vd 0 dc 3.3
vss vss 0 0
vin 1 0 dc 2
OP'et. dc vin 0 3,3 0,01
. udskrive dc v (3)
. sonde
. lib 'mm0355v.l' tt
. valgmuligheder Ingold = 2 csdf = 2
. udgangen
Jeg har lige bruge tsmc 'lib
og jeg hånd beregning af kn = 143u kp = 62.5u
fra lib vthn = 0,536 vthp = 0,736
så what'wrong med mit design.
Hjælp!
Hej,enheden operation er ikke kun afhænge af geometri (W & L) det afhænger også af terminal spænding for (vgs, VDS, vbs)
i ur tilfælde VDS ikke matching for M5 & M8 (diode tilsluttet), så u get forskellige strømninger.Dette problem er helt grundlæggende at nuværende spejle, henvises der til litteratur og bøger i forbindelse med den løbende spejl design.Den femte, Gama værdier stemmer ikke overens med de værdier rapporteret i dine op rapport for enheder fra Hspice.
Tak,
