hvordan du justere kredsløb?
F
freetofree
vdd = 3, ,35 um FMO'er, teleskop
____
-o | | o-vb1 = 2,0850
-o | | o-vb2 = 1,8474
- | | - Vb3 = 904.7771m
- | | - Vin VIC = 787.48m
| - Vfb = 902.86m
nu halen nuværende NMOS er i lineære regionen, andre i aktive region, hvordan du justerer kredsløbet, så det kan fungere i aktive region?
forbløffende
Du bedes lægge dit kredsløb ....hvad du har beskrevet ved hjælp af tegn er ikke så klar ....
Du kan øge input transistor W / L at falde Vgs, så drain spænding af halen aktuelle kilde transistor stige.
. titel simulering af OTA
. PROT
. model nm nmos plan = 49
Version = 3,11 acm = 3 hdif = 0.5e-6
Mobmod = 1.000000e
00 capmod = 1.000000e
00 nqsmod = 0.000000e
00Tox = 6.500000e-09 cdsc = 1.000000e-10 cdscb = 0.000000e
00Cdscd = 3.146578e-03 cit =-1.165567e-03 nfactor = 2.067847e
00Xj = 2.000000e-07 VSAT = 1.733115e
05 på = 4.587946e
04A0 = 1.208623e
00 AGS = 2.664144e-01 a1 = 0.000000e
00A2 = 3.926521e-01 keta =-5.969015e-03 nch = 3.053200e
17K1 = 7.823191e-01 kt1 =-2.968857e-01 kt1l = 6.948321e-09
Kt2 =-2.439718e-02 k2 =-5.976393e-02 K3 =-2.348052e
00K3b =-2.995700e
00 w0 = 0.000000e
00 nlx = 2.343014e-07
Dvt0 = 1.904429e
01 dvt1 = 8.095353e-01 dvt2 = 6.252991e-03
Dvt0w = 0.000000e
00 dvt1w = 0.000000e
00 dvt2w = 0.000000e
00Drout = 5.600000e-01 dsub = 5.891755e-01 vth0 = 4.452273e-01
Ua =-1.085785e-09 ua1 = 2.451017e-09 UB = 2.210053e-18
Ub1 =-2.617479e-18 uc = 3.755569e-11 uc1 = 2.640885e-13
U0 = 3.324764e-02 Ute =-1.230449e
00 voff =-8.793706e-02
Delta = 9.688553e-03 rdsw = 4.385596e
02 prwg = 1.000000e-01
Prwb =-7.964250e-02 prt =-4.162666e
01 eta0 = 1.722893e-01
Etab =-5.113721e-02 pclm = 9.585992e-01 pdiblc1 = 2.537726e-12
Pdiblc2 =-3.312959e-04 pdiblcb =-1.000000e-03 pscbe1 = 5.656369e
08Pscbe2 = 1.000000e-03 pvag = 1.000001e-12 WLO = 9.107508e-01
Dwg =-7.427878e-09 dwb =-3.328336e-09 B0 = 1.598826e-07
B1 = 5.141988e-17 alpha0 = 0.000000e
00 beta0 = 3.000000e
01Elm = 5.000000e
00 cgsl = 0.000000e
00 cgdl = 0.000000e
00Ckappa = 6.000000e-01 cf = 9.056200e-11 CLC = 1.000000e-07
Tikel = 6.000000e-01 tnom = 2.500000e
01 cgso = 1.590000e-10
Cgdo = 1.590000e-10 cgbo = 0.000000e
00 xpart = 1.000000e
00Rsh = 0.000000e
00 pb = 5.112000e-01 MJ = 3.872000e-01
Mjsw = 3.872000e-01 pbsw = 5.112000e-01 cj = 8.488000e-04
Cjsw = 4.896000e-10 støv = 2.345145e-09 ll = 1.382235e-09
LLN = 2.000000e-01 LW = 0.000000e
00 lwn = 0.000000e
00LWL = 0.000000e
00 wint = 1.347400e-07 wl = 0.000000e
00Wln = 1.000000e
00 ww =-7.781819e-14 wwn = 1.000000e
00WWL = 0.000000e
00 nlev = 2.000000e
00 kf = 0.500000e-25
. model pm pmos plan = 49
Mobmod = 1.000000e
00Cdscd = 0.000000e
00 cit = 2.849258e-03 nfactor = 0.000000e
00Xj = 2.000000e-07 VSAT = 1.235253e
05 på = 0.000000e
00A0 = 5.534111e-01 AGS = 0.000000e
00 a1 = 0.000000e
00A2 = 4.000000e-01 keta =-4.742392e-03 nch = 1.198869e
17K1 = 5.036882e-01 kt1 =-4.972940e-01 kt1l = 0.000000e
00Kt2 =-4.796538e-02 k2 = 1.710970e-02 K3 =-1.532555e
00K3b =-1.426295e-01 w0 =-5.128171e-07 nlx = 1.500000e-07
Dvt0 = 1.318457e
00 dvt1 = 2.383284e-01 dvt2 = 0.000000e
00Dvt0w = 0.000000e
00Drout = 3.972895e-01 dsub = 4.287821e-01 vth0 =-7.891688e-01
Ua =-7.838913e-10 ua1 = 4.158887e-09 UB = 1.416209e-18
Ub1 =-3.635865e-18 uc =-3.193134e-11 uc1 = 0.000000e
00U0 = 8.644306e-03 Ute = 0.000000e
00 voff =-1.619864e-01
Delta = 1.000000e-02 rdsw = 1.393589e
03 prwg =-7.131702e-02
Prwb =-9.573077e-02 prt = 0.000000e
00 eta0 = 5.324062e-02
Etab = 0.000000e
00 pclm = 1.294956e
00 pdiblc1 = 1.272241e-02
Pdiblc2 = 5.045117e-04 pdiblcb =-8.715370e-03 pscbe1 = 4.803844e
08Pscbe2 = 1.000000e-08 pvag = 0.000000e
00 WLO = 8.585317e-01
Dwg =-1.637238e-08 dwb =-3.444345e-09 B0 = 0.000000e
00B1 = 1.000000e-04 alpha0 = 0.000000e
01Elm = 5.000000e
00 cgsl = 0.000000e
00 cgdl = 0.000000e
01 cgso = 4.035600e-10
Cgdo = 4.035600e-10 cgbo = 0.000000e
00Rsh = 0.000000e
00 pb = 9.316000e-01 MJ = 4.845000e-01
Mjsw = 4.845000e-01 pbsw = 9.316000e-01 cj = 1.117000e-03
Cjsw = 4.764000e-10 støv = 5.034766e-08 ll = 4.395297e-17
LLN = 1.370692e
00 LW = 0.000000e
00 lwn = 0.000000e
00LWL = 0.000000e
00 wint = 1.924185e-07 wl = 0.000000e
00Wln = 1.000000e
00 ww =-9.207185e-13 wwn = 8.342567e-01
WWL = 0.000000e
00 nlev = 2.000000e
00 kf = 0.250000e-25
. unprot
. valgmuligheder post sonde MEASDGT = 7
. globale vdd
OP'et
vpower vdd 0 3* bias
ibias vdd N7 10u
Mb_M5 N8 vb1 vdd vdd pm W = 10u L = 1u M = 1
Mb_M6 N9 vb1 vdd vdd pm W = 10u L = 1u M = 1
Mb_M7 N10 vb1 vdd vdd pm W = 10u L = 1u M = 1
Mb_M8 N11 vb1 vdd vdd pm W = 10u L = 1u M = 1
Mb_M9 vb1 vb2 N8 vdd pm W = 10u L = 1u M = 1
Mb_M10 N12 vb2 N9 vdd pm W = 10u L = 1u M = 1
Mb_M11 VMI vb2 N10 vdd pm W = 10u L = 1u M = 1
Mb_M12 vbc vb2 N11 vdd pm W = 10u L = 1u M = 1
Mb_M13 vb2 N13 vb1 vdd pm W = 12u L = 2.4u M = 1
Mb_U6 N7 N7 0 0 nm W = 12u L = 2u M = 1
Mb_U7 N12 N12 vb3 0 nm W = 12u L = 0.6u M = 1
Mb_U15 vpp N12 N14 0 nm W = 5u L = 20u M = 1
Mb_U16 vb3 N12 vpp 0 nm W = 12u L = 4.2u M = 1
Mb_U8 N15 N14 0 0 nm W = 12u L = 0.8u M = 2
Mb_M14 N13 N13 vb2 vdd pm W = 12u L = 0.35u M = 1
Mb_U9 VMI vb3 N16 0 nm W = 8U L = 0.6u M = 2
Mb_U10 N16 VMI N15 0 nm W = 12u L = 0.6u M = 2
Mb_U11 N17 vbc 0 0 nm W = 12u L = 0.8u M = 1
Mb_U12 N13 N7 0 0 nm W = 12u L = 2u M = 1
Mb_U13 vbc vpp N17 0 nm W = 12u L = 0.6u M = 2
Mb_U14 N14 vpp N15 0 nm W = 12u L = 0.6u M = 2* teleskop
M_M1 N1 vb1 vdd vdd pm W = 10u L = 1u M = 3
M_M2 N2 vb1 vdd vdd pm W = 10u L = 1u M = 3
M_M3 om vb2 N1 vdd pm W = 10u L = 1u M = 3
M_M4 op vb2 N2 vdd pm W = 10u L = 1u M = 3
M_U1 op vb3 N3 0 nm W = 5u L = 0.5u M = 1
M_U2 om vb3 N4 0 nm W = 5u L = 0.5u M = 1
M_U3 N4 ip N5 0 nm W = 5u L = 0.5u M = 1
M_U4 N3 i N5 0 nm W = 5u L = 0.5u M = 1
M_U5 N5 vfb 0 0 nm W = 10u L =. 5u M = 1C_C1 på 0 1.1p
C_C2 op 0 1.1p
* stimulation
V_vb vfb 0 902.86m
V_vic i 0 DC 852.5m
V_vid ip i DC 0V AC 1V 0
*. dc v_vic .5 1,5 0,0001
. sonde mod (til).
OP'et
. udgangen
det er vanskeligt at læse netlist, jeg går ud fra, at vi taler om den nuværende synkehastigheden for differenstryk par.Følgende forklaring er baseret på min antagelse:
Din NMOS dræn er i lineære regionen.
Tou vil behovet for at øge VDS på tværs af det, som kun kan incresed ved incresing gaten spænding på input af forskellen par.
Hvis du ikke kan gøre dette, thensee hvis du kan redues de vdsat for den aktuelle synke.
Hvis det ikke er muligt, ændre arkitektur.
fordi din vin> femte 2 * vdsat, din vthn = 450mv og vin = 787.48mv, så du skal redue de vdsat af den nuværende synker og input MOS
