H
hover
Hej alle
For nylig har jeg skrevet koden til asynkron FIFO.
Nedenfor er min kode:Kode:
modul asyn_FIFO (Data_out, FIFO_full, FIFO_empty, Data_in, write_clk, read_clk, write_to_FIFO, read_from_FIFO, reset);parameter FIFO_width = 8;
parameter FIFO_height = 8;
parameter FIFO_ptr_width = 3;output [FIFO_width-1: 0] Data_out;
output FIFO_full;
output FIFO_empty;input [FIFO_width-1: 0] Data_in;
input write_clk;
input read_clk;
input write_to_FIFO;
input read_from_FIFO;
input reset;reg [FIFO_ptr_width-1: 0] write_addr, read_addr;
reg [FIFO_width-1: 0] Data_out;
reg [FIFO_width-1: 0] FIFO [FIFO_height-1: 0];wire read_synch;
wire write_synch;
wire [FIFO_width-1: 0] Data_middle;integer i;tildele FIFO_full = ((write_addr == read_addr) & & (write_to_FIFO == 1));
tildele FIFO_empty = ((write_addr == read_addr) & & (read_from_FIFO == 1));altid @ (posedge write_clk eller posedge reset)
if (reset) begynder
write_addr <= 3'b000;
for (i = 0; i <= FIFO_height-1; i = i 1)
FIFO <= 8'b0000_0000;
ende
else if ((write_synch )&&(! FIFO_full)) begynder
FIFO [write_addr] <= Data_middle;
write_addr <= write_addr 1;
endealtid @ (posedge read_clk eller posedge reset)
if (reset) begynder
read_addr <= 3'b000;
Data_out <= 8'b0000_0000;
ende
ellers begynder
if ((read_synch )&&(! FIFO_empty)) begynder
Data_out <= FIFO [read_addr];
read_addr <= read_addr 1;
ende
endesynchronizer_write s1 (Data_middle, write_synch, write_clk, write_to_FIFO, reset, Data_in);
synchronizer_read s2 (read_synch, read_from_FIFO, read_clk, reset);endmodulemodul synchronizer_write (Data_out, write_synch, CLK, Data_valid, reset, Data_in);parameter Data_width = 8;output [Data_width-1: 0] Data_out;
output write_synch;input CLK;
input reset;
input Data_valid;
input [Data_width-1: 0] Data_in;reg Data_valid_synch;
reg write_synch;
reg [Data_width-1: 0] Data_out;altid @ (posedge CLK eller posedge reset)
if (reset) begynder
Data_valid_synch <= 0;
write_synch <= 0;
ende
ellers begynder
Data_valid_synch <= Data_valid;
write_synch <= Data_valid_synch;
endealtid @ (posedge CLK eller posedge reset)
if (reset)
ellers begynder
if (write_synch)
Data_out <= Data_in;
endeendmodulemodul synchronizer_read (read_synch, read_from_FIFO, clk, reset);output read_synch;
input CLK;
input reset;reg meta_synch, read_synch;altid @ (posedge CLK eller posedge reset)
if (reset) begynder
meta_synch <= 0;
read_synch <= 0;
ende
ellers begynder
meta_synch <= read_from_FIFO;
read_synch <= meta_synch;
endeendmodule
output FIFO_full;
input write_clk;
input read_clk;
wire write_synch;
if (reset) begynder
ende
if (reset) begynder
ende
ellers begynder
ende
input reset;
input Data_valid;
reg write_synch;
if (reset) begynder
write_synch <= 0;
ende
ellers begynder
if (reset)
ellers begynder
if (write_synch)
input CLK;
if (reset) begynder
meta_synch <= 0;
read_synch <= 0;
ende
ellers begynder
endeendmodule
