Urgent!
B
balaece07
Hej Alle,89s52[/b] Microcontroller Using I2C..I tried So many Times....But Didnt get the output..
Bala Here.I jeg forsøger at kommunikere TO
89s52 [/ b] Microcontroller Brug I2C .. Jeg har prøvet så mange gange .... Men Didnt få produktionen ..
Her er jeg herunder min kode .. PLS finde fejlen og Hjælp mig ..
Tahnks in Advance
kode:
# include <AT898252.h>
# include <intrins.h>
unsigned char readI2c (bit ACK_Bit);
void writei2c (unsigned char W_Byte);
void writemc (unsigned char adr, unsigned char data1);
void readmc (unsigned char addr);
sbit SDA = P0 ^ 1; / / forbinde til SDA pin (Data)
sbit SCL = P0 ^ 0; / / forbinde til SCL pin (ur)
forsinkelse ();
void main ()
writemc (0x24, 0x55);
readmc (0x24);
/ / Start I2C
void Start (void)
SDA = 1;
SCL = 1;
_nop_ (); _nop_ ();
SDA = 0;
_nop_ (); _nop_ ();
SCL = 0;
_nop_ (); _nop_ ();
/ / Stop I2C
void stop (void)
SDA = 0;
_nop_ (); _nop_ ();
SCL = 1;
_nop_ (); _nop_ ();
SDA = 1;
/ / Skriv I2C
void writei2c (unsigned char data)
unsigned char i;
for (i = 0; i <8; i )
SDA = (Data & 0x80)?1:0;
SCL = 1;
SCL = 0;
Data <<= 1;
forsinkelse ();
SCL = 1;
_nop_ (); _nop_ ();
SCL = 0;
/ / Read I2C
unsigned char Data = 0;
unsigned char i;
SDA = 1;
SCL = 1;
Data <<= 1;
Data = (Data | SDA);
SCL = 0;
_nop_ ();
forsinkelse ();)
if (ACK_Bit == 1)
SDA = 0; / / Send ACK
anden
SDA = 1; / / Send NO ACK
_nop_ (); _nop_ ();
SCL = 1;
_nop_ (); _nop_ ();
SCL = 0;
return data;
Start ();
writei2c (0xC0);
writei2c (addr);
writei2c (data1);
Stop ();
void readmc (unsigned char addr1)
unsigned char rdata;
Start ();
writei2c (0xC0);
writei2c (addr1);
Start ();
writei2c (0xC1);
rdata = readI2c ();
Stop ();
P2 = rdata;
forsinkelse () / * One Second Delay * /
T2MOD = 0x03;
TL2 = 0xFC;
TH2 = 0xFE;
TR2 = 1;
while (TF2! = 1);
TR2 = 0;
TF2 = 0;
HI
Så vidt jeg husker 8.952 ikke har hardware IC slave interface.
I2C interface due to complicated trimming requirement for the slave
Der for det vil være meget vanskeligt eller tæt på idømmes for at skrive en software-slave
I2C interface på grund af komplicerede trimning krav om slaven
Kun hurtig controller (ligesom STM32 eller PIC24 og PIC32 eller AVR) kan emulere software I2C slave
Alle de bedste
Bobi
Den microcontroller specialist
godt, kan det gøres med afbryder ...bruge dem begge ...
så skal vælge, hvilken en vil være herre, og som man vil være slave ...
der begge som master / slave kunne være meget vanskeligt (voldgift ting og så ...)
Hej,
Hvis du har SPI protokol indbygget i din microcontroller, end det vil virke som en Master & Slave.
Bare se til.
Hilsen
Chanchal
