H
ht lab
If you are a Modelsim/Questa user you might have spotted that 2022.1 has just been release and to my surprise it supports VHDL2019 conditional compilation!
The documentation is a bit sketchy so here is how to use it:
1) Define a VHDL2019 `if construct:
`if CONST_OVERRIDE=\"1\" then
constant my_val: integer := 10;
`else
constant my_val: integer := 11;
`end
2) compile your code with:
vcom test.vhd -vhpreprocess -definevh CONST_OVERRIDE=1
3) run vsim
you will notice that depending on the -definevh value you either get 10 or 11. Also note the use of double quotes in the code and no quotes on the vcom line.
You will also have a bunch of predefined constants such as VHDL_VERSION, TOOL_VENDOR etc.
Now fingers crossed they will add more VHDL2019 support.....
Regards,
Hans
`else
`end
3) run vsim
Regards,
Hans
