Disabled generate give compile error in Modelsim...
S
Stef
It has been a while since I used VHDL so I am a little rusty. Did not
much use the generate statement in the past either. And now I have the
problem that I have (been given) a VHDL model that has a conditional
generate in it. And this does not work as I expected. In the model, the
purpose of the conditional is that there is a clock source that cannot be
simulated, so an alternative is simulated. I have reproduced the problem
in the minimal example below.
If I decalare \'sigio\' as \'inout\', as below and as I got the model, then when
I simulate it, the signals in the simulation remain \'U\'. So somehow the
\'gentest\' model drives the \'sigio\' signal although the generic
\'this_is_a_simulation\' has been set to true.
If I declare \'sigio\' as \'in\' (change the comment line in the port), I get a
compilation error in Modelsim on driving the type \'in\' \'sigio\' signal. When
I then just comment out the \'rtlblk\' generate, the model simulates as
expected.
Can this be made to work as expected (simulation/pll model switch without
changing the code)? Unfortunately I cannot get information from the original
creator of this construct and I don\'t know if it ever worked.
-------- gentest.vhd ------------
library ieee;
use ieee.std_logic_1164.all;
entity gentest is
generic(
this_is_a_simulation : boolean := true
port(
-- sigio : in std_logic;
sigio : inout std_logic;
sigout : out std_logic
end entity gentest;
architecture behav of gentest is
begin
rtlblk : if this_is_a_simulation = false generate
sigio <= \'1\';
sigout <= \'1\';
end generate;
simblk : if this_is_a_simulation = true generate
sigout <= sigio;
end generate;
end architecture behav;
-------- tb_gentest.vhd ------------
library ieee;
entity tb_gentest is
end entity tb_gentest;
architecture behav of tb_gentest is
signal clk : std_logic;
signal sigout : std_logic;
begin
gentest_inst : entity work.gentest
generic map(
this_is_a_simulation => true
port map(
sigio => clk,
sigout => sigout
process
begin
clk <= \'0\';
wait for 10ns;
clk <= \'1\';
wait for 10ns;
end process;
Stef
Hey, where did that sig go?!
